Dustin_V's avatar
Dustin_V
NETGEAR Employee Retired
Apr 01, 2019
Notice: NETGEAR Genie App Will No Longer Be Updated; Switch to the New Nighthawk app
We want to continue providing you with new mobile app features for the best WiFi experience. That’s why we’ve decided to focus our efforts on improving the new Nighthawk app. As a result, the Genie app will no longer be updated.
Download the Nighthawk app today to keep your router up-to-date with the latest features and security updates. Check here to see if your WiFi router is supported:https://kb.netgear.com/000055505/Which-routers-support-the-NETGEAR-Nighthawk-app
The NETGEAR Nighthawk app lets you monitor and manage your WiFi from anywhere. Easily pause WiFi, test your internet speeds, or turn on Guest WiFi.
If your router is not supported by the Nighthawk app, don’t worry – you can still use genie app features.
To download the Nighthawk App, visit: Nighthawk-App.com
