Orbi WiFi 7 RBE973
Reply
R6100 not updating to latest firmware
enzone45
Initiate
Hello,
I received an email from Netgear earlier to update my R6100 to latest version firmware v1.0.1.28 . When I try through the genie app on my Samsung galaxy s7 smartphone to update it says I have the most updated firmware but it's still at v1.0.1.22 . My genie app version is 3.1.78 and the new nighthawk app does not support my router. Any ideas? Please help,
Thank you 🙂
Model: R6100|AC1200 Dual Band Router
Message 1 of 4
Accepted Solutions
Guru
Re: R6100 not updating to latest firmware
Glad to hear it. If you mark the answer as solved it helps the next person with this issue
Message 4 of 4
All Replies
Guru
You can login to the router via a browser at routerlogin.net
From there you can auto update (I don't recommend) or you can manually update it. I highly recommend updating it over a hardwired connection and resetting afterwards. Tends to give you the best results and least problems.
The release notes walk you through a manual update.
https://www.netgear.com/support/product/R6100.aspx
Message 2 of 4
enzone45
Initiate
Thank you! The firmware update worked with me doing a wired connection to the router and a manual update. All good now👍
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5103 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
