- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300v2 Firmware Update Fail
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300v2 Firmware Update Fail
Is there a v2 after the model on the bottom label with the model number on it?
Version 2 firmware should be 1.0.4.8 for the R6300v2 and version 1 should be 1.0.2.80 for the R6300.
What firmware did you try update too ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Download it to your desktop from here: https://www.netgear.com/support/product/R6300v2.aspx#download - then update your router, browsing to your desktop for the router firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will it work with a snartphone or a tablet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem with updating the firmware via wifi if you lose the wifi connection during the process the router could be bricked but the router should auto update the firmware when you log into the router.
Page 15 tells about the firmware update process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rwmt wrote:
Why does the firmware version my router is currently using (V1.0.3.6_1.0.63CH) not appear in the list of older firmware versions for R6300V2 routers? And why does it say there are no new firmware versions available when I use the Internet search on routerlogin.com? I have attempted to update to all firmware versions above V1.0.3.6_1.0.63CH and all of them have said they are incorrect for this router (R6300V2) How can this be? What can I do to get this router firmware up to date so I can begin operating on ipv6?
You can download the firmware from this link https://www.netgear.com/support/product/R6300v2.aspx#Firmware Version 1.0.4.8
You can manually update the firmware via the download from Netgear the version of the firmware may be the version that it shipped with.
When offers to options to update from the web or manual use manual and select the location that you saved the new firmware too on your computer via a wired lan cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having this EXACT same issue. I have a R6300V2 router that will not update. My firmware version is currently V1.0.3.6_1.0.63CH which, as was already pointed out, does not appear in the list of older firmware versions for R6300V2 routers. My computer is directly connected to the router when I try to update, but it says there are no new firmware versions available. I have also downloaded, extracted, and attempted to update to all firmware versions above V1.0.3.6_1.0.63CH, yet all of them say that they are incorrect for this router (R6300V2)... I have even tried reverting back to factory default settings just to see if that would help, but I still get the same results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible that the isp has a special version to work on their networks and they alone can update the firmware must modems work that way if you rent the router may be it is time to buy your own router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyway, thanks for the "help" and the constructive criticism Richard!
See you next Tuesday ; )
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
