Orbi WiFi 7 RBE973
Reply
Remote access
Deb318
Tutor
Remote access
How come I can setup remote access from my desktop but I can't through the app. Keeps saying internal error.
Message 1 of 6
DexterJB
NETGEAR Moderator
Re: Remote access
Hi @Deb318,
1. What is the model number and firmware version of the router?
2. What device are you using (Android, iOS)?
3. Are you referring to the remote login feature of the NETGEAR Genie app?
4. Please try using another device (Android, iOS).
Dexter
Community Team
Message 2 of 6
Deb318
Tutor
Re: Remote access
Model# R7000 Version: V1.0.8.34  Apple Iphone6 and Yes having trouble with the App. and I have tried other devices.
Message 3 of 6
DexterJB
NETGEAR Moderator
Re: Remote access
Hi @Deb318,
1. Have you tried uninstalling and re-installing the app/s?
2. Have you tried resetting the device?
Dexter
Community Team
Message 4 of 6
Deb318
Tutor
Re: Remote access
Yes did both of those!
Message 5 of 6
DexterJB
NETGEAR Moderator
Re: Remote access
Hi @Deb318,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 6 of 6
Discussion stats
  • 5 replies
  • 3289 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
