Orbi WiFi 7 RBE973
Reply
Viewing networks
JG75
Viewing networks
After installing the new router Nighthawk AC 1900 I can’t view available local networks on my communication devices when I select “WiFi.” I am trying to reconnct my Deere security cameras but can’t see them pop up as a network device so I can choose. In fact, I can’t see any other networks except for my own. I am on Apple devices. Any ideas?
Message 1 of 5
Accepted Solutions
Re: Viewing networks
@JG75 wrote:
Thanks. Found the answers. Appreciate ur help. Problem solved.
That's good.
Care to share the answers with other people who might turn up here with the same problem?
Message 4 of 5
All Replies
AC1900 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds.
You might get better and quicker replies, and find other answers, over in the appropriate section for whatever hardware you own.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
Message 2 of 5
JG75
Message 3 of 5
That's good.
Message 4 of 5
schumaku
Guru
Unclear at what state of installation you are - the mobile devices (iPhone, iPad, MacBook, ...) can't see the unspecified AC1900 class the new router to configure it, or what exactly do you try to achieve?
Don't understand what or how you try to (re-)connect these security cameras, where they are supposed to pop-up. If the cameras used to connect to a different wireless router before, they will continue to try reaching that very same network again.
A smart advise would be to configure the new router to the same network name and security key (wireless passphrase) as your old wireless - like that you should not have to reconfigure all these fancy IoT stuff.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1798 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
