Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
can't really disable dchp?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-08-19
03:43 AM
2016-08-19
03:43 AM
I'm trying to use the Genie D1500 as a simple wireless access point for a network. The network already has an existing DHCP server, so I don't need the router to hand out adresses.
However, if I turn off the DHCP server option, the router still hands out adresses, from the grayed out range on the config page.
It also sets itself as the gateway, whereas I really need the existing server to be the gateway.
What gives?
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-08-19
07:12 AM
2016-08-19
07:12 AM
Re: can't really disable dchp?
When you turned off the DHCP Server Option, did you click Apply to save the change? Try power cycling the router.
Message 2 of 2
Announcements
