Orbi WiFi 7 RBE973
100% CPU USED(MODEL: BR500)
toya
Tutor
hi
 I think vpn router has a issue.
 though I use about 20 devices (pc,sockets,cctv,nvr,smartphone),
 100% CPU Usage is too much.
 Before it was 20~30%(i guess).
 why is it happened?
thx
Model: BR500|Insight Instant VPN Router
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: 100% CPU USED(MODEL: BR500)
@toya,
What is the current firmware version of your BR500?  If ever its not yet the latest version, I suggest you to upgrade it.  The latest BR500 firmware is v5.10.0.5 and you can download it here.  Then observe if the same problem will occur.
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 603 views
  • 1 kudo
  • 2 in conversation
Announcements
