Orbi WiFi 7 RBE973
Alternative for BR200/BR500 for 10GBit/s
Dear community,
I have a couple of BR200/BR500 routers coupled with many other insight products from the business series. Recently, my provider upgraded all fibre optic speeds from 1Gbps to 10Gbps. Since the BR200/BR500's cap at 924 Mbps WAN/LAN throughput, I was wondering if there is an alternative from netgear with comparable features. I'm receiving via DHCP request a public IP via ethernet. I guess I could use a managed switch (routing capabilities), but I would loose all the other security features like SPI as far as I'm aware of. Any ideas?
Thanks a lot and best regards,
Aristo
Model: BR500|Insight Instant VPN Router
Message 1 of 2
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Alternative for BR200/BR500 for 10GBit/s
@Aristomastrosi,
There is no alternative as of now.  I suggest you post your concern as a product/feature request in the Ideas Exchange for Business board here.  In this way, the development team can see what product/feature does users wanted.  Be reminded that the more kudos given by community members to your product/feature request will help as the development team will be reviewing the post that has the most kudos and might get considered.
DaneA
NETGEAR Community Team
Message 2 of 2
All Replies
DaneA
@Aristomastrosi,
DaneA
Message 2 of 2
Discussion stats
  • 1 reply
  • 1633 views
  • 0 kudos
  • 2 in conversation
Announcements
