- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BR200 can't forward a port no matter what I try :(
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi, first post although I've been all over the web (including here) to try to figure out what is going wrong.
I'm not any sort of "pro" when it comes to networking, but, I bought this BR200: 1) to connect to my FiOS service, 2) since I didn't want/need a Wifi AP, 3) because I wanted to isolate Guest network to a different subnet
I was able to accomplish everything I wanted easily with the BR200, except port forwarding and I have no idea what is wrong. All I'm trying to do is add forwarding rules for my IP cameras which I've been able to do on every router I've owned except this one.
For example, if I set up the most basic forward of HTTP to one of my IP cameras, it doesn't work (connection timeout). Nothing shows up in the log either. I also tried adding a variety of Port Triggers and Traffic Rules, but, that didn't help either.
Is there anything I need to do other then set up a port forward rule?
Thanks for any help/advice.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hmmm, yes ... there was something. Give me a minute please.
Found it. The current BR200 Firmware Version 5.10.0.5 (also the one for the BR500, and some minor versions before) says this:
Known Issues:
NAT loopback does not work in this release. NAT loopback is useful for accessing internal resources by public domain name.
Workarounds: Use one of these workarounds:
- Change device hosts file to map public domain name to local IP when working on the same subnet as a public server.
- Use a separate DNS server that can handle accessing public resources from an internal network.
Downgrade to a previous released firmware with NAT loopback support.
Scratch the last suggested workaround, this applies to the BR500 only.
Sorry, I'm compereably "new" back on the BR500/BR200 8-)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: BR200 can't forward a port no matter what I try :(
Does the BR200 WAN/Internet address as shown on the Dashboard match to the "Google what is my IP address"?
If not, there is another NAT router in front, either as part of your connection, or in the form of the ISP CPE WiFi router?
Almost forgot: How are you testing the port forwarding: From the wild Internet, or from the LAN(x) via NAT loopback?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you for your reply! To answer your questions.
Yes, this is confirmed the same.
No, the BR200 is connected directly via ethernet right into FiOS ONT.
Actually, no, I always test via a PC or phone on my LAN. Does this not work with this router?
Thank you for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Known Issues:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I didn't even know this was a thing (NAT loopback). Hopefully they will enable this in a future release so it isn't necessary to have to keep reconfiguring the app accessing these devices to use different IP addresses whether I'm on my local network or not. But I'm glad I can access them at all.
Thank you so much for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
