- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BR500 DHCP via WAC510 - Not working on VLAN1
- Mark as New
- Bookmark
- Subscribe
- Permalink
A week ago I replaced my BR500 router (due to an ongoing issue with regular disconnect/psuedo reboots). I was able to capture the configuration and get it set back up the way the old one was. Had a brief issue providing IP addresses to mobile devices on via my WAC510 on VLAN 1 / Management VLAN - but rebooted the setup and then it worked.
A few days later it simply stopped supporting mobile devices via the wireless, but provides IP addresses to laptops on wireless and any computers on the wired network. I have tried rebooting both devices. I have even reset the configuration on the WAC510, but to no avail. I have even setup a new wireless SSID - connect to management VLAN and mobile devices cannot get an IP. Change that SSID to another VLAN and it works fine. Took working connections on other VLANs, switch to the management VLAN and same problem. Mobile devices only seem to be impacted.
I have tried requesting help, but even though they just replaced the BR500 under warranty - I cannot create a new support issue at this time. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BR500 DHCP via WAC510 - Not working on VLAN1
Found out from the NETGEAR Support Team that a support ticket has been opened regarding your concern. You can login to your MYNETGEAR account and send a follow-up message through the support ticket. Also, you may want to post here the progress of it.
DaneA
NETGEAR Community Team
