Reply
BR500 - SHA2?
train_wreck
Luminary
BR500 - SHA2?
Just looked at the datasheet for the newly-released BR500 VPN router:
https://www.netgear.com/images/datasheet/security/BR500.pdf
One glaring omission; SHA2 in the VPN algorithms. The highest hashing algorithm listed is SHA-1.
Surely this device supports SHA2 family hashes? (256,384,512). Yes?
(by the way, your forum does not offer the BR500 as an item in the "Model" field for new posts.)
Message 1 of 3
DaneA
NETGEAR Moderator
Re: BR500 - SHA2?
Hi @train_wreck,
I inquired your post to the higher tier of NETGEAR Support.  As per the higher tier of NETGEAR Support, the Insight Mesh VPN supports 521 bits ECDSA keys, AES-256-CTR + HMAC-SHA256.
DaneA
NETGEAR Community Team
Message 2 of 3
DaneA
NETGEAR Moderator
Re: BR500 - SHA2?
@train_wreck,
I just want to follow-up on this.  Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
Message 3 of 3
Discussion stats
  • 2 replies
  • 969 views
  • 0 kudos
  • 2 in conversation
Announcements
