- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BR500 VPN Currently Experiencing Intermittent Connectivity Issues - Reply Thread
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BR500 VPN Currently Experiencing Intermittent Connectivity Issues - Reply Thread
WTH!
We are trying to have people work from home! That doesn't work when the VPN service is down. None of my VPN is working and hasn't been working for 24 hours now.
NETGEAR - This isn't a science experiement. You discontinued service on very reliable products (FVS336 & FVS318) and now we have this. And again, you couldn't have picked a worse time.
Yes I have rebooted
Yes I have tried connecting direct using a PC & Insight
Nothing is working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know that its not much help but here is the last update that was provided:
I subscribed to this and it is usually my first check when I have issues.
I have reached out to support for this issue this morning as well, and we gathered logs from one of my BR500's, I was told that I will hear back from them today. I will try to follow up with a post when I have confirmed that the devices are up and stable for a little while.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still down on my routers. Even the IPsec tunnels don't stay up on these routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have noticed that as well. Although with my setup, I was only able to config my side, while the other organization configured their gear. It bounces a couple of times an hour typically.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Insight VPN service has been restored. You should now be able to re-connect either their Site-to-Site or Client-to-Site VPN connections. You may need to restart their BR500 and/or VPN client in order to re-establish the VPN connection. Please let me know if you have any further issues with the VPN service and we can escalate accordingly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
VPN is still coming and going. I've rebooted multiple times, both servers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All my customers in South Africa are down again!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
in France too !
We come back several month ago in the same situation.
BR500 + insight cloud = bad solution ( 6 firmware updates in one year !!!)
Good luck...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Back the FVS336. Down all night. Down right now. I've rebooted and rebooted. The BR500s are talking to the Insight cloud, as I can reboot using the app. But the VPN never reconnects.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Don't comme back to FVS336 => GUI is not compatible with modern web navigator...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yanked out a pair of BR500 at one clients and put back in FVS336v3 in their place. Got a tunnel up and running with no issues.
Also the latest quirk with the BR500 that started Sunday is that in Insight Portal it can not connect. I have to log in locally and reboot for it to connect. Three of these so far have done this.. All with firmware 5.8.0.1. Oops today makes the fourth to do it. I get NO alerts say router is offine,,,,weird things
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still down. It seemed to work for short periods of time last night. But would drop the connection.
I tried the following:
Log off of the VPN client, and log back in, with same results.
Close the client, end the Insight, and virtual VPN adapter processes, and then relaunch the application and tried to connect with the same results.
I rebooted the BR500 with the Insight App, with no change.
This morning, we have no connectivity again, The VPN client is showing that the router is online half of the time and offline half of the time, but there is no connectivity issue at the site.
So far I have tried the following:
I physically rebooted the BR500 this morning, with no change.
I also tried both of the VPN client steps above, with the same issue.
Also after the reboot the option to select my Proxy is now gone.
I will update my ticket with Netgear and let everyone know if I find out anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
In all cases you must select a proxxy first (adresseIP_router/support.html) and click submit (on each router you need to connect between us)
After you reboot.
You wait several minutes before you can see a goog link (green) on insight (less if you look in GUI of your router).
Normally it's good... but not since yesterday...
Too much connections because COVID19 ?
All Europe works at home via VPN...
Good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Francis78 wrote:Hi,
If you use "Edge" the interface works fine. Chrome has issues with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR!
Any update on the server problems?
I may "play around" over the weekend when I have time and my business isn't depending on the VPN service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have reached out to support the last two days to check on the status. I was told that they are aware of the issue and that my ticket has been escalated. I have noticed that in the late evenings and early morning that I can get the VPN client to connect after trying several times, but by typical business hours there is no connection. It really is random as well. I can get a test system to establish the VPN and then try to fire up a client connection with no success.
I have them on fall back Splashtop connections, but the speed and some of the application features are not available.
I have some very frustrated staff and clients to say the least.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Is there still connectivity issues on the BR500? and is there any idea when this will be resolved?. The Insight status show last update Wed 18 2020.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing works here either. Even with a subscription.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope... still issues. Last night I was able to delete the VPN group via tha app and create a new one. This gave us connnectivitiy after a little waiting.
This morning the VPN is down again. Both units appear online but the VPN is showing a red-dashed connection.
I've been dealing with this terrrible product for over a year. Every time we've been ready to throw it in the trash, it becomes stable for a few months. Going to look for a stable alternative.
When does the class action start against Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have found that the insight app, and the vpn clients are not accurate, atleast for the time being. I have been able to establish a connection with them showing the device as offline. Level 2 and 3 support emailed to let me know they have been working on my case, and I am currently testing. (I am seeing TTL's that are starting to level out, but earlier they were all over the place) I will try to post an update at the end of the day as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I set mine up with OpenVPN instead and that is still working without trouble. It's also included with the BR500, try switching to that if you can log into the units for the time being.
Honestly I'm not sure I will ever use the Netgear VPN connection because it doesn't seem to ever work reliably. I will let these units run there course and then they will be replaced with another brand... I guess we get what we pay for...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jkfcb1975 wrote:I set mine up with OpenVPN instead and that is still working without trouble. It's also included with the BR500, try switching to that if you can log into the units for the time being.
What is really frustrating is that they HAD perfectly operable products, FVS336 & FVS318. They abondoned these and want us to use thier "subscription" service. We not only paid for the devices, we are paying for a service that is causing the problems.
How much did each of us pay for these BR500 VPN devices? With all of the issues, I have spent FAR more in time trying to get these to work and keep them working. I am looking for alternative manufacturers right now. One brand name company, I can buy their smaller device for $125 per VPN router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We need an official response acknowledging this outage and what steps are being taken to resolve the issue once and for all. We have been beta testers for well over a year and it’s not okay.
