Orbi WiFi 7 RBE973
FVS318N Firmware version 4.3.3-8 Open Source Code for Programmers Bad File on Server
SamirD
Prodigy
I was trying to download the Open Source firmware code v4.3.3-8 for my FVS318N here:
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL
And it seems the file is corrupted on the server.  It downloads correctly, but the file inside the zip should be 97MB and the whole zip is just over 5MB and files a zip test function. All the other files for the FVS318N download and test fine--it's just 4.3.3-8 (the one that I want).  Can someone fix this and post here when it is done so I can download the file?
Message 1 of 5
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: FVS318N Firmware version 4.3.3-8 Open Source Code for Programmers Bad File on Server
Hello @SamirD,
I'm glad to inform you that the Open Source firmware code v4.3.3-8 for the FVS318N has been fixed. 🙂  Kindly check it.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 4 of 5
All Replies
DaneA
Hi @SamirD,
Thank you for posting this.  I already sent a message to our NETGEAR Web Content Specialist to address this concern.  I will post here once I got a feedback.
DaneA
Message 2 of 5
SamirD
Prodigy
Thank you!
Message 3 of 5
DaneA
Hello @SamirD,
DaneA
Message 4 of 5
SamirD
Prodigy
Thank you!  I just checked the zip and it's a-okay now. 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1960 views
  • 0 kudos
  • 2 in conversation
Announcements
