- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FVS318N Setup help
- Mark as New
- Bookmark
- Subscribe
- Permalink
FVS318N Setup help
Hello, I'm currently trying to setup a FVS318N in our office. I am rather confused though.
Basically we have an ADSL router in the room and what I would like to do is connect that to the FVS318N and then share the internet from the FVS318N. I would also like to plug a NAS server in to the firewall.
Is this configuration possible ? I have managed to share the internet by plugging a patch cable into a port on the firewall. However if I plug that patch cable into the WAN it does not share the internet connection.
Am I right in saying that the internet should be plugged into the WAN port ? Sorry I'm a bit confused by all of this.
The ADSL router is a Sagemcom 2704N.
Many thanks
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: FVS318N Setup help
Hi k1llercop,
Welcome to the community! 🙂
I found out online that the Sagemcomm 2704N is a combination of ADSL modem and wireless router. For you to maximize the functionality of the FVS318N as a VPN firewall, I suggest you to configure the Sagemcomm 2704N as a modem-only device. Then, connect the Sagemcomm 2704N to the WAN port of the FVS318N. Thus, making the FVS318N as the main router since the WAN IP Address will be registered to it. Then, configure the FVS318N and finally you may connect your NAS to one of the LAN ports of the FVS318N.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
@killercop,
Were you able to try to set the Sagemcomm 2704N as a modem-only device set to full-bridge mode? Then, making the FVS318N set as the main router?
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello DaneA thanks for the response. Unfortunately there are no options on the Sagemcomm to put it into modem only mode. Do you hava any other suggestions ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi k1llercop,
Do you have an old DSL modem that you can try to use? Or, if ever the Sagemcom 2704N was provided by your ISP to you, you might want to exchange it to a device that is a combination of ADSL modem and router wherein its possible to configure it as a modem-only device set to full-bridge mode.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi k1llercop,
Just want to follow-up on this.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello k1llercop,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
NETGEAR® Community Team
