Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FVS336G - multi homing configuration problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
11:07 AM
2011-11-17
11:07 AM
Hi,
I have two different networks:
192.168.22.0/24
172.16.248.128/25
FVS336G firewall's IP is 192.168.22.1. This is also the default network gateway.
FVS336G multi homing settings are:
IP: 172.16.248.254
NETMASK: 255.255.255.128
The hosts connected to the second network are using 172.16.248.254 as gateway.
I'm able to ping a public IP form the first network but I cannot from the second network.
The message error is Destination Host Unreachable.
where I'm wrong ?
In the routing table of the FVS336G I don't see any rule that involve the second network subnet, is that correct ?
Thanks,
192.168.22.0/24
172.16.248.128/25
IP: 172.16.248.254
where I'm wrong ?
Thanks,
Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
11:27 AM
2011-11-17
11:27 AM
Re: FVS336G - multi homing configuration problem
Add Secondary LAN IP Address
To add a secondary LAN IP address, type in the IP Address and the Subnet Mask in the respective text fields and click Add.
Note: Additional IP addresses cannot be configured in the DHCP server. The hosts on the secondary subnets must be manually configured with the IP addresses, gateway IP and DNS server IPs
try gateway with 192.168.22.1
Message 2 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
11:49 AM
2011-11-17
11:49 AM
Hi thanks for your response.
I've tried to do this but I cannot because the gateway's IP is not in the host subnet.
Have I to setup some routing rule in the FVS336G ?
Message 3 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
12:01 PM
2011-11-17
12:01 PM
ftp://downloads.netgear.com/files/FVS336Gv2_RM_14_April10v.pdf
p38.
p38.
The secondary LAN IP address will be assigned to the LAN interface of the VPN firewall and can be used as a gateway by computers on the secondary subnet.
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
12:02 PM
2011-11-17
12:02 PM
Good news !
I've hard-restarted the FVS336G and all works fine !
Thank you !
Thank you !
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-17
12:08 PM
2011-11-17
12:08 PM
oh... lucky..lol
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-18
12:28 AM
2011-11-18
12:28 AM
Question June, Does the secondary network have DHCP as well, or is it only for the primary LAN?
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-18
04:40 AM
2011-11-18
04:40 AM
There is no dhcp on multi homing
Srxn with 4wan has vlan which can do dchp on each vlan
Or prosecure UTM
Or prosecure UTM
Message 8 of 8
