Orbi WiFi 7 RBE973
Reply
FVS336Gv2 connecting to Sky Fibre
DRBYEBYE
Hi Guru's
I have just got hold of a fvs336gv2 from work which was surplus to requiremnets and thought id try and get it running at home with my Sky Fibre set up.
Im sure im almost there with the set up but i'll be blowed if i can get the internet conection up and running.
I have the standard Openreach FTTC modem connected to WAN1 and below are whats in the 2 relevant WAN configuration screens:
If i click the "Auto Detect " button it tells me that there is a PPPoE connection.
I have tried all sorts of variations in the fileds and have my extracted UN & PW from my old Sagem router. I have also read loads of stuff regarding Option 61, MER and DHCP authenticaion from sky but am now in overlaod mode !!
Has anybody got the same / similar set up working.??
Cheers !
Model: FVS336Gv2|PROSAFE DUAL WAN GIGABIT FIREWALL WITH SSL & IPSEC VPN
Message 1 of 4
SamirD
Prodigy
Re: FVS336Gv2 connecting to Sky Fibre
What did your network look like before you added in the fvs336?
(My hunch is that you have to select no login and just dhcp, but I want to make sure.)
Message 2 of 4
DRBYEBYE
Hi. Thanks for the reply.
Just a straight forward openreach modem and a rubbish sky sagem router.
Message 3 of 4
SamirD
Prodigy
Was the setup on the existing router PPPoE?  Or did it just get a dhcp ip address?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4757 views
  • 0 kudos
  • 2 in conversation
Announcements
