Reply
FVX538 Firewall Bandwidth Management
Andreapier
Is it possible to limit bandwidth on one (or more) specific LAN ports?
I.E., I'd like to set LAN1 to 20Mbps (in/out) and LAN2 to 80Mbps.
Thank you!
Andrea
Model: FVX538|ProSafe High-Performance VPN Firewall
Message 1 of 3
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: FVX538 Firewall Bandwidth Management
Hi Andreapier,
Welcome to our community! Smiley Happy
As per checking, FVX538 does not support rate limiting per LAN and this type of configuration is only supported by a fully managed L3 Switch.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 3
All Replies
JohnC_V
NETGEAR Moderator
Hi Andreapier,
Message 2 of 3
Andreapier
Hi JohnCarloV!
Thanks for your answer, I'll search for a small managed switch to do the job. :-)
Best regards,
Andrea
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1073 views
  • 0 kudos
  • 2 in conversation
Announcements
