Reply
I need reset vpn client
vsacanell
Follower
Hello:
We have updated some computers in the office and I would need to be able to install the vpn client in the new ones, I do not see how to uninstall them from the old ones so I can reassign them.
In another thread I have seen that if an administrator is asked if it is possible, is that the case?
Thank you
Model: GS110TP|ProSafe 8 ports gigabit PoE smart switch
Message 1 of 2
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: I need reset vpn client
Hi vsacanell,
Welcome to our community! Smiley Happy
Thanks for reaching out directly to me. We already reset the VPN License key and you can now install it to your new PC.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
Message 2 of 2
All Replies
JohnC_V
NETGEAR Moderator
Hi vsacanell,
JohnCarloV
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 686 views
  • 0 kudos
  • 2 in conversation
Announcements
