Orbi WiFi 7 RBE973
IPSec site to site VPN BR200 Access devices
chrisonline
Tutor
I have set up a the first time a IPSEC site to site connection to another router.
My IP Range is 192.168.100.0 and MASK 255.255.0.0 (Router A - Netgear BS200)
The other site has a 192.168.1.0 and MASK 255.255.255.0 (Router B - Linksys)
The connection is green inside the BS200 webinterface.
So the tunnel should be working.
I am currently with my notebook in the 192.168.100.x network and want to connect to the Router B webinterface via 192.168.1.1 but this does not work. I am getting always Connection Timeout.
Also I can't ping any device.
Do I miss something? Can anybody help?
Thanks
Message 1 of 2
Accepted Solutions
chrisonline
Tutor
Re: IPSec site to site VPN BR200 Access devices
SOLUTION:
I need to create a static route that the IP range 192.168.1.x will go to the external WAN IP Address.
After creation all is working.
Message 2 of 2
All Replies
chrisonline
Tutor
SOLUTION:
Message 2 of 2
Discussion stats
  • 1 reply
  • 743 views
  • 1 kudo
  • 1 in conversation
Announcements
