Reply
IPTV with FVG318
magomic
Follower
IPTV with FVG318
Hi guys,
is it possible to activate multicast (iptv) support for fvg318 firewalls?
I know there is no built-in function to do so. So i'm thinking about to get an open source firmware which supports iptv, but i have no idea if this is possible?
Message 1 of 2
DaneA
NETGEAR Moderator
Re: IPTV with FVG318
Hi magomic,
As per this link, there is no open source firmware available for the FVG318.  The FVG318 is already End-of-Life.  However, you may post your concern about creating an open source firmware for the FVG318 on the Idea Exchange for Business board here.  Give kudos to your post.  The more kudos, the more it will get attention and it might be possible to be implemented.
Also, I searched online and found this link below about opening ports for IPTV on the FVG318.  Kindly check it as reference and this might help you:
http://portforward.com/english/routers/firewalling/Netgear/FVG318/MY-IPTV_Anywhere.htm
Hope it helps.  Welcome to the community! Smiley Happy
DaneA
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 2999 views
  • 0 kudos
  • 2 in conversation
Announcements
