Orbi WiFi 7 RBE973
Reply
Multiple private networks from one ISP for IOT, and wired devices and wireless devices and guest.
DDIIorio
Follower
Looking for a solution to secure wired computers from wireless devices and seperate IOT devices. Wanting more security to separate devices with multiple radios, to secure security devices like ring devices, nest thermostats....
Need help finding the best solution.
Model: BR500|Insight Instant VPN Router
Message 1 of 2
Guru
Re: Multiple private networks from one ISP for IOT, and wired devices and wireless devices and guest
I've got my SXK30 setup similar. It allows vlans by ethernet and wireless ssid. You can have up to 4x ssids.
If you're needing more performance, there is the SXK80 series as well.
Message 2 of 2
Discussion stats
  • 1 reply
  • 630 views
  • 1 kudo
  • 2 in conversation
Announcements
