Orbi WiFi 7 RBE973
Reply
NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3 is manageable to static DNS?
vedicsys
NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3 is manageable to static DNS? We want to add our local IP's into this device as static DNS routing. Please help on this.
Model: FVS336Gv3|ProSafe dual WAN gigabit firewall with SSL and IPSec VPN
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3 is manageable to static DNS?
Hi vedicsys,
Welcome to our community! 🙂
Yes, you may use your local DNS to the FVS336Gv3. Please check the manual on page 33.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1366 views
  • 0 kudos
  • 2 in conversation
Announcements
