Orbi WiFi 7 RBE973
Reply
PR60X Managing hosts file
jimbo67
Hello, for some reasons i would need to update the hosts file of the touteur  ( cannot access lan website using names and ssl with wireguard since i left cloudflare for a cheaper solution ).
But since we cannot access it with ssh nor telnet.
Is it possible to make a option for updating the hosts file directly from the web interface ?
Or is it absolutly not possible ?
Message 1 of 11
jimbo67
Re: PR60X Managing hosts file
Message 2 of 11
jimbo67
And then https://kb.netgear.com/000066031/How-do-I-enable-NAT-loopback-on-my-PR60X-or-PR460X
Well kinda strange but it works after i moved the web server port from the mx510txp to one of the pr60x port.
Message 3 of 11
jimbo67
And without the loopback i had lost insight mangement too. I just realised when the blue light came back after switch the port.
Anyway would be so much easier to be able to update hosts from web interface.
Message 4 of 11
jimbo67
Well i was wrong it solved one part of the problem as accessing local somme application using port 443 on server pinpointing to wan adress.
But since i used ip filtering to access toses server it doesnt work when i tried to access them using vpn I tried ipsec,openvpn and wireguard but none can access those url.
Message 5 of 11
c3po2
Apprentice
Hi Jimbo, Could you please let us know exact issues so that we can try to reproduce the issue and see if we can have workaround, for examples:
LAN (or WAN) has issue to access LAN (or WAN) using IP (or DDNS Domain name) through VPN (or not) - If there is issue, what is the symptom? Thanks.
Message 6 of 11
jimbo67
Hi c3po2.
IT small structure is behind the pr60x.
But i am only using wan2 port 5 reconfigured and port 10g is connected to a ms510xtup.
Wan1 is connected to the 4g backup my isp provided and is rarely used.
Services are hosted at office.
Vpns have access to all vlans.
This is for the short config.
When i was using cloudflare as a proxy everything worked fine. Sometimes with some headache with cloudflare tunnels.
Than i decided to host again everyrhing
at office.
Than i encountered this problem.
I can access everithing using ip with vpn.
But from wan to lan the domain name doest resolv with the vpn.
The trick to use another port on the prx60 for the servers worked to acess domain name from lan again.
But it didnt to acess the domain name with the vpns.
Nat hairpin trick with physical port change for lan loopback isnt enough to make it work.
And i have no idea how to fix this.
Message 7 of 11
jimbo67
Also everything works fine from wan.
But i wan to acess it using vpn connected to the phones.
Yet my workaround is to access it using auth method throught https with a nginx proxie to redirect.
I can also use the vpn and access ressources with ip.
But i would prefer to acess it with the vpn using https with domain name.
Yea i know its absolutly overkilll and useless.
I dont want to start modify Android or Apple config file just for that.
Message 8 of 11
c3po2
Apprentice
Thank you for detailed description, we will try to setup same network as yours to see if we can make improvements for your application.
Message 9 of 11
jimbo67
I modified the /etc/hosts file to match my domainename.eu on the server i use as the dns proxy running for local.
Than forced the router to use it to enjoy the loopback ability of the router.
It works fine using this setup but still not while using the vpn.
Only solution yet is to use cloudflare dns proxies to acess those domain with the vpn.
Well i'm not trying anymore to make the vpn work to access my domainname using my sertigo ssl on my services localy hosted.
Message 10 of 11
BrianL
NETGEAR Moderator
Hi @jimbo67,
This is not possible at this time. You may want to create a new thread or post here.
Kind regards,
BrianL
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1170 views
  • 0 kudos
  • 3 in conversation
Announcements
