Orbi WiFi 7 RBE973
Reply
ProSafe VPN Client Activation License?
chantastic
How can I obtain a license for ProSafe VPN Client Professional for my ProSafe VPN Firewall SRXN3205 if I lost my original one?
Thanks,
Dan
Message 1 of 4
DaneA
NETGEAR Employee Retired
Re: ProSafe VPN Client Activation License?
@chantastic,
Welcome to the community! 🙂
Were you able to register your ProSAFE VPN Client Professional Software license key before?  If yes, kindly send me via private message the e-mail address you have used when you registered your ProSAFE VPN Client Professional Software license key before so that I can inquire it to the higher tier of NETGEAR Support.
DaneA
NETGEAR Community Team
Message 2 of 4
chantastic
I’ve sent you a PM.
Thanks
Message 3 of 4
DaneA
@chantastic,
I just sent you a pm.  It is now clear that you are referring to the NETGEAR VPN Client Lite License that should be bundled with your SRXN3205.  You may now try to register the  NETGEAR VPN Client Lite Software License Key provided.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1442 views
  • 0 kudos
  • 2 in conversation
Announcements
