eldonkey's avatar
eldonkey
Prosafe FVS124G VPN Ipsec keeps disconnecting every minute
Hi, i've just fresh configured my FVS124G after updating firmware to latest version and i have an issue with VPN IPsec connection.
I'm using same saved profile for the client, and almost stock configuration from VPN wizzard on the router. It was working fine some time ago but now after successfully connecting client it keeps disconnecting after about 70-80 seconds.
attaching client console log, also no errors from server side.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    eldonkey,
    Welcome to the community! :)
    Kindly answer the questions below:
    a.  Is the VPN tunnel working fine before you did a firmware upgrade on the FVS124G?
    b.  What is the VPN Client software that you are using?  Is it the NETGEAR VPN CLient Lite software or the NETGEAR VPN Client Professional software?
    c.  What is the current version of the VPN Client software that you are using?
    Since you did a firmware upgrade on the FVS124G, I suggest you to perform a factory reset on it so that it would start clean using the latest firmware version.  Then, reconfigure everything from scratch.  Once there is internet access through the FVS124G, use the VPN Wizard to configure the VPN settings and configure the VPN Client software from scratch as well.  Check if the same problem will occur.
    DaneA
    NETGEAR Community Team
    • eldonkey's avatar
      eldonkey
      Hi, sorry for late anwser. I was able to get it working. Kind of. I disabled DPD completly and it is working fine for 2-3 hours, but only if there was constant traffic like a running RDP session. Maybe the device is faulty. I did tried to reset it twice.
      > Tunel was working fine before the upgrade.
      > Software was NETGEAR VPN Client Professional and later TheGreenBow
      > I was using latest trial version - fresh downloaded
ProSupport for Business
