Orbi WiFi 7 RBE973
Reply
Random tunnel disconnects.
I_am_jbcbussoft
I have a tunnel setup using a FVS318N and two VPNG01L clients. One of these is rock solid with no problems. The other randomly drops out. I would like to determine what is the problem but the log files aren't always available due to restarts etc. Is there a way to capture the VPN log files from the client side? iI was notified of a connection loss at 11:44AM. I got there and the logs from that time were gone. In the log I found these two lines:
(I had to type these)
20160708 12:11:43:734 Default (SA Ikev 1Gateway-P1) SEND Informational [HASH] [DELETE]
20160708 12:11:43:734 Default <Ikev 1Gateway-Ikev-Tunnell-P2> deleted
I terminated the connection manually and got these:
(Once again I typed these)
20160708 12:20:05:881 Default (SA Ikev 1Gateway-P1) SEND Informational [HASH] [DELETE]
20160708 12:20:05:881 Default <Ikev 1Gateway-Ikev-Tunnell-P2> deleted
So my manual disconnect and an unwanted disconnect look the same. How do I determine what is going on?
Model: FVS318N|ProSafe Wireless N 8 port gigabit VPN firewall,VPNG01L|ProSafe VPN Client Professional (1-user)
Message 1 of 3
DaneA
NETGEAR Employee Retired
Re: Random tunnel disconnects.
Hi I_am_jbcbussoft,
Kindly answer the questions below:
a. Are the two VPNG01L clients on the same LAN?
b. What is the Operating System of the 2 PCs where the VPNG01L clients are installed?
c. Are there any software firewall or anti-virus as well as any apps running on the  VPNG01L client that randomly drops out?
Let me share the old article below and it might help:
Understanding the VPN logs – ProSafe VPN Client
DaneA
NETGEAR Community Team
Message 2 of 3
DaneA
Hi I_am_jbcbussoft,
Just want to follow-up on this.  Were you able to read the article I've shared?
DaneA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3371 views
  • 0 kudos
  • 2 in conversation
Announcements
