- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Recommended router and VPN
- Mark as New
- Bookmark
- Subscribe
- Permalink
New to Netgear. Is there a plan to launch a rack-mounted router, and if so, what are the expected release date and if known, key specs?
In the meantime, what (a) rack-mounted router and (b) VPN are recommended for use in a small business with very simple networking requirements and the following planned devices:
• 2 x stacked M4300-52G-PoE+'s
• 3 x Netgear's forthcoming WiFI 6 WAPs
• 1 x ReadyNAS RR4312X2
• 3 x VLANs
• ~20 x Mac client computers
Main desiderata for the router and VPN are:
• ease of installation/setup
• ease of maintenance
• reliability
• speed
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Recommended router and VPN
Kindly check the NETGEAR Insight Instant VPN Router which is the BR500 and it is currently available in the market. You can install it in a standard 19-inch (48.26-centimeter) network equipment rack. Also, you can use any off-the-shelf 100 mm VESA standard mount to secure the router to a wall, a pole, or another surface.
With the BR500, you can configure Site-to-Site VPN using the NETGEAR Insight VPN up to 3 BR500. Also, you can configure Client-to-Site VPN using the NETGEAR Insight VPN wherein up to 10 VPN Client users can remotely connect to the BR500.
For more information about the specifications of the BR500, kindly access its data sheet here. Check also the BR500 webinar here.
Check the links below on how to configure VPN using the NETGEAR Insight Instant VPN:
How to Set Up Remote VPN with NETGEAR Insight Instant VPN?
How to Set Up Site-to-Site VPN Using NETGEAR Insight Instant VPN?
To know more about NETGEAR Insight, kindly access the links below:
What can I do with NETGEAR Insight?
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much. If we forgo the VPN, what rack-mounted Netgear router would be recommended for this setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
