Orbi WiFi 7 RBE973
Reply
Remote DNS for IPSec Tunnel Not Correct
jxdomb
I can establish a tunnel using the full VPN client to the FVS318N.  Routing into the remote private LAN works as expected.  However, DNS does not resolve to any of the names in the private LAN.  How can I adjust the IPSec policy and/or VPN client settings to get the private LAN's DNS server working?  Thanks!
Model: FVS318N|ProSafe Wireless N 8 port gigabit VPN firewall
Message 1 of 5
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Remote DNS for IPSec Tunnel Not Correct
Hi jxdomb,
Welcome to the community! 🙂
I am not sure if this will help.  However, let me share this forum link I found online.
DaneA
NETGEAR Community Team
Message 2 of 5
All Replies
DaneA
Hi jxdomb,
DaneA
Message 2 of 5
JohnRo
Hi jxdomb,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Message 3 of 5
jxdomb
The forum link did help me to understand that I needed to manually configure the remote subnet and DNS parameters in the VPN client, or to use a mode config record to have that information be provided by the router during negotiation.
Thank you!
Message 4 of 5
DaneA
Hi jxdomb,
I'm glad that the forum link I found online has helped you. 🙂
Feel free to post your future concerns here in the community.
Cheers,
DaneA
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3415 views
  • 0 kudos
  • 3 in conversation
Announcements
