Orbi WiFi 7 RBE973
Reply
Replace FVS336Gv2 with v2 or v3?
fred339
Tutor
We have an FVS336Gv2 that has been the workhorse for a serious business installation.
We're using the VPN capability very much.
The router has become flaky: it loses internet connectivity frequently and often has to be rebooted to return to service.
So, unless someone suggests otherwise, I'm thinking of replacing it very soon.
I see that I can purchase FVS336Gv2 devices and imagine that I might use the existing configuration to save time and effort in configuring one of those.
I also see that I can purchase FVS336Gv3 devices and HOPE that I might use the current configuration file on that.
Is that possible?
Notwithstanding my desire to preserve the configuration and save work, what would be the recommendation for a selection to replace the FVS336Gv2?
I'm supporting the office remotely and need to be able to do the replacement with a minimum of fuss.
Model: FVS336Gv2|PROSAFE DUAL WAN GIGABIT FIREWALL WITH SSL & IPSEC VPN
Message 1 of 4
JohnC_V
NETGEAR Moderator
Re: Replace FVS336Gv2 with v2 or v3?
Hi fred339,
Unfortunately, we cannot use the configuration file from the old version to the new version. They have different firmware versions. I suggest, take a screenshot of all the configurations from the old firewall, then use it as a copy for the newer version.
John
NETGEAR Community Team
Message 2 of 4
fred339
Tutor
So, are either of these still in support?
Message 3 of 4
JohnC_V
NETGEAR Moderator
@fred339,
Yeap, we do still provide support on these models as long as it still under warranty.
You may check our warranty policy here.
John
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1080 views
  • 0 kudos
  • 2 in conversation
Announcements
