Orbi WiFi 7 RBE973
SRX5308 bootloader checksum error
Jcasas334
Follower
I got the test-light-of-death on this box out of no where, the box bricked hours after making a change to the reboot schedule. the device does not respond at all from any network interface. Connecting to the console port, it is clear that something corrupted the onboard OS image, there is a checksum error;
U-Boot 1.1.1 (Development build, svnversion: exported) (Build time: Jan  6 2011 - 16:15:26)
Warning: Board descriptor tuple not found in eeprom, using defaults
CUST_SRX5308 board revision major:2, minor:0, serial #: unknown
OCTEON CN5010-SCP pass 1.1, Core clock: 700 MHz, DDR clock: 200 MHz (400 Mhz data rate)
DRAM:  512 MB
Flash: 64 MB
Clearing DRAM....... done
BIST check passed.
Net:   octeth0
== Executing bootcmd in 5 seconds - enter ctrl+c to abort        0
Checksum error!!
SRX5308 bootloader#
I would imagine the box could be recovered with a tftp load via the console. Is there a procedure and the proper files available to un-brick this box?
Model: SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Message 1 of 2
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: SRX5308 bootloader checksum error
@Jcasas334,
So far, there is no procedure to unbrick the SRX5308.  You will need to replace it.
DaneA
NETGEAR Community Team
Message 2 of 2
All Replies
DaneA
@Jcasas334,
DaneA
Message 2 of 2
Discussion stats
  • 1 reply
  • 2385 views
  • 0 kudos
  • 2 in conversation
Announcements
