Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SRXN3205 - VPN Access to LAN Resources
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
01:55 PM
2011-07-28
01:55 PM
Good Day,
I have the SRXN3205 all setup and working, following the manual I have setup both a IPSEC and SSL VPN, using either of these I cannot ping any devices on the internal network except for the SRXN's LAN IP. I know the devices can respond to ping as I can ping them from the SRXN's diagnostics. Is there something noticeable I could be doing wrong? Thanks.
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-15
02:48 PM
2011-08-15
02:48 PM
Re: SRXN3205 - VPN Access to LAN Resources
If you can ping the LAN gateway, but no network resource the problem is with the firewall/security software on the computer. Either uninstall the software, disable it completely(go through services.msc all services related), configure it to trust the IP address you're coming from. If using SSL this IP address is generally 192.168.251.x unless you changed it
Message 2 of 2
