Orbi WiFi 7 RBE973
VPN Client License Key reset
SebTracor
Tutor
Hello team,
We have a problem with license pro VPN
2 of our PC are crashed and licenses are burned
Is it possible to reset the license code to install it on news notebooks ?
Thanks for your help
Sebastien
Model: FVS336Gv3|ProSafe dual WAN gigabit firewall with SSL and IPSec VPN
Message 1 of 5
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: VPN Client License Key reset
@SebTracor,
I just got a feedback from the higher tier of NETGEAR Support that your VPN license key associated with the e-mail address you have sent via private message has been reset.
You may now register the VPN license key to your new notebooks.
Since your concern has been resolved and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 4 of 5
All Replies
DaneA
@SebTracor,
Welcome to the community! 🙂
I got your private message.  I already sent a request to the higher tier of NETGEAR Support to reset the VPN license key.  I will post here once I got a feedback.
DaneA
Message 2 of 5
SebTracor
Tutor
Many thanks for your help !
Regards
Message 3 of 5
DaneA
@SebTracor,
DaneA
Message 4 of 5
SebTracor
Tutor
Great result !
Many thanks for your help in very fast answer !!!
Thanks !
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2021 views
  • 0 kudos
  • 2 in conversation
Announcements
