- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN Client VPNG01L VPNG05L
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need a license for the Netgear VPN Client Pro VPNG05L or VPNG01L.
In the past I purchased it from Netgear4Less.com but can't find it anymore.
EOL or not I need a license and am not in a possition to change products at this time.
Can anyone help me purchase a KEY?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN Client VPNG01L VPNG05L
Hi @Augello,
I suggest you to kindly check your past e-mails you got from Netgear4Less.com and you might find the VPN license key you have purchased from them.
Both of the VPNG05L or VPNG01L are already EoL. If ever you have already registered your VPNG05L / VPNG01L license keys you have purchased before, kindly send me via private message the e-mail address/es you think that you might have possibly used when you registered it and I'll make a request to have it check.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks: Your suggestion was spot on.
One other simular issue you might help with is restoring a VPN Lite Client key.
I uninstalled the Netgear ProSafe VPN client Lite 4.6 from a laptop, which should have released the software key. But after installing the client on the user's new laptop the key won't activate.
Can you help?
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mike,
What is the error code when you activate the license key?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Activation error 34: The license can not be used to activate THE software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Troubleshoot Software Activation
Errors can occur during the activation process. Each activation error type is displayed on the Software Activation page.
You can resolve most of errors by carefully checking the following:
• Verify that you entered the correct license number. (Error 031 indicates that the license
number was not found.)
• Your license number could already be activated (Error 033). Contact NETGEAR support.
• Your license number cannot be used for activation (Error 034). Contact NETGEAR
support.
• A firewall might block communication with the activation server (Error 053 or Error 054).
Find out if a personal or corporate firewall is blocking communications.
• The activation server might be temporarily unreachable. Wait a few minutes and try
again.
