Orbi WiFi 7 RBE973
Reply
VPN Connected, but know what to do?
Ok, so I've been able to make VPN connectivity between two locations but cannot find the remote computers in my File Explorer.  Am I supposed to use Remote Desktop or something else to find these machines, NAS, etc.?
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: VPN Connected, but know what to do?
Hi BSM_ENGINEERING,
Well, it depends on how you wanted to access the files in your network. You may use RDP or you may share the specific folder in public or to a specific user so that you can have an access to it.
I hope this articles would help.
- How to view a list with all shared network folders in Windows
How to Access Network Resources Over a VPN
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1184 views
  • 0 kudos
  • 2 in conversation
Announcements
