Reply
VPN from two different networks
Arix
Follower
Hi,
Sorry if this question has been done by someone before; I have a SRX5308 and I need to configure two vpn on it using different lan and wan ports:
1. 1 server from my lan (15.20.25.1) to one external server from another company (30.31.32.5) using a private link (on Clear Channel or MPLS)
2. 1 server from my lan (15.20.15.2) to one external server from another country (190.20.21.11) using internet
The first vpn use the first lan port and wan1, every thing goes up with no problem.
The second use the second lan port and wan2, everything is connected but wan2 never goes up.
This configuration can be done with this firewall/vpn (and I'm doing something wrong)?? or I'm asking to much to one device and I must use a second firewall/vpn??
Thank you for all advise that everyone can bring me.
Arix
Message 1 of 3
JennC
NETGEAR Employee Retired
Re: VPN from two different networks
Hello Arix,
Welcome to the community!
You may need to check the WAN mode settings of your router.
JennC
NETGEAR Community Team
Message 2 of 3
JohnRo
Hi Arix,
In addition to @JennC's response, my suggestion is to create two different IPsec VPNs (one for each network). Once done, check if you are using "Primary WAN Mode". Also, make sure that both VPNs are workingby trying to switch WAN ports being used.
If you have more questions, we'll be happy to help.
Thanks,
JohnRo
NETGEAR® Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3590 views
  • 0 kudos
  • 3 in conversation
Announcements
