Reply
VPNG05L need licence key reset
LasseWeihe
Follower
Hey
We bought a VPNG05L in may 2013. The client uses 3 licences but we can not add another pc.
2 PC's have been replaced since 2013 without the licenses being properly uninstalled, I think that's why there is a problem.
Can you help getting the last 2 licences to work?
The VPNG05L was bought by a Preben Egerup. Im not sure what email was used for the purchase, but perhaps it was : preben.egerup@schneider-electric.com
Thank you for your help.
Model: VPNG05L|ProSafe VPN Client Professional (5-user)
Message 1 of 3
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: VPNG05L need licence key reset
Hi LasseWeihe,
Welcome to our community! Smiley Happy
May you be able to send me the VPN license key via PM? I'll forward it to our engineering team to have it reset.
I'm looking forward to your reply.
Message 2 of 3
All Replies
JohnC_V
NETGEAR Moderator
Hi LasseWeihe,
Message 2 of 3
JohnC_V
NETGEAR Moderator
@LasseWeihe,
Your license key has now been reset. Please try if you can now install it.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Discussion stats
  • 2 replies
  • 1010 views
  • 0 kudos
  • 2 in conversation
Announcements
