Orbi WiFi 7 RBE973
Reply
VPNG05L reset license
LAK1
Hello, I´ve changed my laptop and install vpn ipsec client but when I try to activate the software I get error code 33 (the license is already activated in other device).
How can I activate the software once again?
Regards.
Message 1 of 4
DaneA
NETGEAR Employee Retired
Re: VPNG05L reset license
@LAK1,
Welcome to the community! 🙂
The VPN license key needs to be reset so that you can use it to the new laptop.  Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. e-mail address/es that was used when you have registered the VPN license key
DaneA
NETGEAR Community Team
Message 2 of 4
LAK1
Hello DaneA,
the license I need reset is the following:
email:d.laquidain@againsl.com
license: 444xxx-xxxxxx-xxxxxx-xxxxxx
Regards
Message 3 of 4
DaneA
@LAK1,
I just got a feedback from the higher tier of NETGEAR Support that your VPN license key has been reset. 🙂  You may now re-register it to your new laptop.
If you were able to re-register it and have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
DaneA
Message 4 of 4
Discussion stats
  • 3 replies
  • 693 views
  • 0 kudos
  • 2 in conversation
Announcements
