Orbi WiFi 7 RBE973
Reply
What is the difference between FVS336G and FVS336Gv3
OWEN22
Hi Hopchen / DaneA,
Good day Sir's
I just want to ask what is the diference of   FVS336G and  FVS336Gv3 is it only a firmware version?
regards,
Owen->Ruel
Message 1 of 10
DaneA
NETGEAR Employee Retired
Re: What is the difference between FVS336G and FVS336Gv3
Hi @OWEN22,
I moved your post to the appropriate discussion board.
Here below are the differences between FVS336G (FVS336Gv1) and FVS336Gv3:
Be reminded that both FVS336Gv1 and FVS336Gv3 are already End-of-Life (EOL).  Kindly check the announcement here.
DaneA
NETGEAR Community Team
Message 2 of 10
OWEN22
Hi DaneA,
Thank you for the info. the product are in EOF, Any other Netgear product router that Vlan Aware that you can recomened DaneA.
Best regards,
Owen
Message 3 of 10
DaneA
@OWEN22,
As per the link I have provided from my previous response, the whole NETGEAR VPN Firewall product line that supports VLAN was recently declared EOL (End-of-Life) last September 1, 2017.  I'm afraid that currently, there is no NETGEAR firewall / router that supports VLAN which is not EOL that I can suggest.
DaneA
Message 4 of 10
OWEN22
Hi DaneA,
Maybe I will stick with the FVS336Gv3, but  I cant find any trusted reseller here in japan can you help me find a good trusted store.
Best Regards,
Ruel
Message 5 of 10
DaneA
@OWEN22,
Let me share you this link: https://netgear.jp/sales/
Hope it helps. 🙂
DaneA
Message 6 of 10
OWEN22
Hi DaneA,
Please confirm if this is the correct version, FVS336Gv3 Thank you very much for warm support.
FVS336G-300NAS
https://www.amazon.co.jp/NETGEAR-ProSafe-FVS336Gv3-Router-4-port/dp/B00O4UJHFG/ref=pd_sim_147_1?_enc...
Best regards,
Ruel
Message 7 of 10
DaneA
@OWEN22,
The FVS336G-300NAS is the product code for FVS336Gv3 for the North America region.  The product ordering information is indicated on page 5 of the FVS336Gv3 data sheet here.
As I understand from the link you have provided, the FVS336Gv3 that you will order will come from North America.  You might want to verify this with https://www.amazon.co.jp.
DaneA
Message 8 of 10
DaneA
@OWEN22,
I just want to follow-up on this.  Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
Message 9 of 10
OWEN22
Dear DaneA,
Yes sir thank you your very helpul..
Best regards,
Ruel/Owen
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3223 views
  • 0 kudos
  • 2 in conversation
Announcements
