- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
srx5308 firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm unable to upgrade my firmware to 4.3.5.3. It keeps taking me back to the login screen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: srx5308 firmware upgrade
Hi @tbparker,
Welcome to the community! 🙂
Kindly try the steps below:
1. Make sure that the PC you are using is directly connected to any of the LAN port of the SRX5308.
2. Clear the cache of the browser you are using then try again to upgrade the firmware of the SRX5308 to v4.3.5.3.
3. Use other browsers such as Firefox or Safari then try again to upgrade the firmware of the SRX5308 to v4.3.5.3.
4. Use other PC or laptop then try again to upgrade the firmware of the SRX5308 to v4.3.5.3.
5. Reboot the SRX5308 then try again to upgrade the firmware of the SRX5308 to v4.3.5.3.
6. If ever the above steps does not work, perform a factory reset on the SRX5308 then try again to upgrade the firmware of the SRX5308 to v4.3.5.3. If ever you are able to upgrade the firmware, perform another factory reset then reconfigure the settings from scratch in order to start clean using the latest firmware version.
Let us know the results.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The factory reset did the trick.. Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the update. I'm glad to know that you were able to upgrade the firmware after doing a factory reset. 🙂
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
