- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cell net gear app connection question
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the WNDR3400v3 series routers to old to use with the android net gear app?
It seems that the app is seeing my wifi, but when I go to login with the default user name and password, it tells me the device is not connected to the WiFi network, when I know it is. This occurs wether or not NetGear Genie is running on my labtop, and I can't acess it from remote acess. Also my router doesn't allow me to sign into my Netgear on the windows application.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cell net gear app connection question
Did you find this?
If you cannot login to your router | Answer | NETGEAR Support
Then again, not what what you mean by " doesn't allow me to sign into my Netgear".
my Netgear what?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I meant to write the My Netgear Genie mobile app
Also I solved it the easy way, I bought a new router, was about time I upgraded to a better router anyhow.
