- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parent control not working (not blocking anything)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260 #2
Physical Address. . . . . . . . . : -----------------------
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.12(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, August 04, 2017 7:54:05 AM
Lease Expires . . . . . . . . . . : Saturday, August 05, 2017 10:24:51 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Address: 192.168.1.1
Non-authoritative answer:
Addresses: 2a03:2880:f126:83:face:b00c:0:25de
31.13.78.35
Aliases: www.facebook.com
Address: 208.67.220.220
which.opendns.com text =
"I am not an OpenDNS resolver."
opendns.com nameserver = auth3.opendns.com
opendns.com nameserver = auth1.opendns.com
opendns.com nameserver = auth2.opendns.com
auth3.opendns.com internet address = 208.69.39.2
auth1.opendns.com internet address = 208.69.39.2
auth2.opendns.com internet address = 146.112.60.53
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @ashutosh22,
1. Please make sure that you have completely disabled/disconnected your separate OpenDNS account from your connected if you have one.
2. Apps are cannot be filtered by LPC since it only works on browsers.
3. Does the issue persist on all devices?
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @ashutosh22,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parent control not working (not blocking anything)
Hi @ashutosh22,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I jump on this thread since my issue is the same/similar.
Right now I'm completely unable in 2017 AD to find working software that lets me block my children's access to certin websites. This is simply unbelievable.
I recently bought an N300 WNR2000v5. After finally getting so-called Parental Controls turned on and downloading some software (thank you to Netgear support), the only features really available to me is to block my kids' computers all-or-nothing and generally filter out adult sites. I want to be able to list specific sites. I've tried adding some like youtube.com and wikipedia.org but it has absolutely no effect at all. What's going on? This seems totally basic.
(Also, I was using OpenDNS separately for a few years but that stopped working entirely. They say it's because I switched all my computers to use IPv6 which I did not, but apparently their stuff doesn't work if that happens. Also, I recently got this new "cheap" router because the $150 ASUS router I was using became completely inoperable with my xfinity cable modem.
Please advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let me amend that previous post. I tried blocking huffingtonpost.com and that worked. ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @nuncvideo,
Did you use the Blacklist/Whitelist option via netgear.opendns.com?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply Dexter.
I couldn't find the blacklist/whitelist option (UI completely changed from what I'm used to) but just as I was responding I decided to click around the netgear opendns site more aggressively and I finally found it! Thank you.
(I'd humbly submit that the UI is sorta broken. The whitelist/blacklist option needs to be on the main filtering page not "Account Settings"!!!
Thanks. I'll see if it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! It worked (after 3 minutes or so).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried everything and my parental control is not blocking anything I currently have the latest firmware installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @kd630,
1. What is the firmware version of the R8500?
2. Does the issue persist on all your devices?
3. Please try changing the filtering level and check if the issue will still persist.
4. Have you tried resetting the router?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
