Orbi WiFi 7 RBE973
Reply
[GC108P] When connected to port 7, it is always 'Connected & Powered'
Garam
Hello.
I am sorry that I am not good at English.
I purchased and installed the GC108P.
PoE seems to be enabled even if it is connected to a computer or router that does not support PoE, and to an upper switch.
Only port 7 and the rest is fine. I wonder if this is an app bug or a bad machine.
(The LAN cable used is different.)
Thanks for reading.
Model: GC108P|Insight Managed 8-port Gigabit Ethernet PoE+ Smart Cloud Switch with FlexPoE Power
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: [GC108P] When connected to port 7, it is always 'Connected & Powered'
Request a replacement from your retailer/shop or challenge Netgear for a hardware replacement via https://my.netgear.com
Message 4 of 4
All Replies
schumaku
Guru
If a factory reset with removal a d re-add the switch to Insight does not recover from the strange port status, suspect it's a hardware issue on the switch.
Message 2 of 4
Garam
After seeing the explanation below, I tried to connect again after initialization, but port 7 still seems to be a problem.
Thank you for your help.
[Return the switch to its factory default settings.] After you use the NETGEAR
Insight app to remove the switch from your network, press the Reset button for
at least five seconds.
The switch restarts and returns to its factory default settings. During this process,
the Power/Cloud LED lights amber.
Message 3 of 4
schumaku
Guru
Message 4 of 4
Discussion stats
  • 3 replies
  • 2304 views
  • 2 kudos
  • 2 in conversation
Announcements
