Orbi WiFi 7 RBE973
Reply
GC752XP trunking to a phone with voice and data VLANs
bobscrew
Follower
Hi
I am installing a Netgear GC752XP in to an office, together with 15 Yealink phones. There will be two subnets:
Existing:               192.168.190.0/24             Data (default VLAN 1)
New:                    10.0.0.0/24                        Voice via a separate gateway
The Data network routes out to the internet using a default gateway of 192.168.190.9 (an IP on the other end of a leased line to another site). There is a DHCP server for this network. Because the routing for data is at the other site, there is no on-premise router for data.
The voice network will route out to a voice provider via their router. This router provides DHCP for the 10.0.0.0 network; the gateway is 10.0.0.254.
The phones have a built-in Network switch and the PC connection is used for a PC (actually a thin-client terminal).
If I were using a Cisco switch , I’d know how to set this up. Cisco has a feature whereby the switchport used for he phone can be configured like this example:
interface FastEthernet0/2
               switchport mode trunk
               switchport trunk native vlan 1
               switchport voice vlan 10
I’d like the phones to Autodiscover the voice DHCP server for the phone service – and for the PC to find the data dhcp server.
I’d like to use the two 1Gb SFP ports of the switch for the two upstream providers (will I need some static routing?)
I have found a Netgear document about Voice VLANs but that assumes an access port with PVID for Voice VLAN and that other ports are used for data.
Attached is a network sketch. I’d be very grateful for some suggestions. Thank you!
Model: GC752XP|Insight Managed 52-Port Gigabit PoE+ Ethernet Smart Cloud Switch with 2 SFP and 2 SFP+ 10G Fiber Ports
Message 1 of 1
Discussion stats
  • 0 replies
  • 902 views
  • 0 kudos
  • 1 in conversation
Announcements
