TheVillageRC
Jan 04, 2024Aspirant
GS752TP Vlan configuration to separate ports
I have several GS752TP switches and have had no issues in the past with various configs. Today I was setting up a new part of our building and wanted to use the 752TP as efffectively 3 switches. I have 3 fibers running over and want to have my main connection carry vlans 1, 2, 7, and 9 and utilize ports 16-32, and use 50 to uplink. I want to use 49 to uplink to another switch carrying a single subnet completely separate from the others (lets call it 20) using ports 1-15, and of course 49. I also want another separate link to port 51 with another subnet using ports 32-48. I set this up as vlan30.
When I set this up on our old HPE3500yl switches it works just as I described. When I try it on the netgear it seems to work but crashes out and loses connectivity when I connect the second link to the subnets.
Thoughts?
- schumakuGuru - Experienced UserCrashing? Reads more like STP or the likes are shutting down a link to avoid some loop conditions. Review your L2 design and configuration.
- TheVillageRCAspirant
Well, yes.... Which would be impossible if the vlans were separating the ports like they should be.
Each group of ports is set up untagged to themselves and no access to the others, but the issue persists. Exact same setup on HPE 3500YL works perfectly. I know the GS752TP isn't an enterprise level unit, but it's got to be able to segregate between ports right? Is there a setting somewhere that tells vlans to isolate from eachother that I'm missing?
Appears you think STP and RSTP is limited to each VLAN - I have to disappoint you, I'm afraid. It's irrelevant if we talk of Netgear or any blue heavy iron - this applies to any brand.
If you are very happy, -and- there is neither STP or RSTP, nor any other L2 loop protection in place, -any- switch will take every VLAN as a dedicated entity, each with it's own IP subnet and broadcast domain.
- ahmad1122Aspirant
Are you still facing this issue?
