Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Insight Smart Cloud Switches 8/10-port models now support static routing!
bradleyv
NETGEAR Expert
Did you know? With the newest firmware release 1.0.4.6, all 8-port/10-port models of the Insight Smart Cloud switches now support static routing, just like the larger port-count rackmount models! IPv4/IPv6 Static routing allows for a simple way to provide segmentation of the network with internal routing through the switch – reserving the router for external traffic routing only, making the entire network more efficient. Currently, static routing needs to be setup using the local-only web GUI, but will soon be available in the Insight mobile app and Insight Cloud portal, so stay tuned for that!insight-switches-2.png
Model: GC110| 8-Port Gigabit Ethernet App Managed Smart Cloud Switch w/2 SFP Fiber Ports,GC110P| 8-Port Gigabit Ethernet PoE App Managed Smart Cloud Switch w/2 SFP Fiber Ports,GC510P| 8-Port Gigabit Ethernet PoE+ App Managed Smart Cloud Switch w/2 SFP Fiber Ports,GC510PP| 8-Port Gigabit Ethernet PoE+ High-Power App Managed Smart Cloud Switch w/2 SFP Fiber Ports
Message 1 of 6
Accepted Solutions
LaurentMa
NETGEAR Expert
Re: Insight Smart Cloud Switches 8/10-port models now support static routing!
Hi @schumaku
Static routing feature has always been available on the 28-port models via the local web GUI; and it will be coming soon in Insight as well.
Laurent Masia
NETGEAR Senior Product Line Manager, Managed Switches
Message 3 of 6
All Replies
schumaku
Guru
Nice, thank you Bradley! Is this feature coming soon to the GC728X/XP?
Message 2 of 6
LaurentMa
NETGEAR Expert
Hi @schumaku
Laurent Masia
Message 3 of 6
schumaku
Guru
Granted - we're using the Insight Switches with Insight management (only), figure....
Message 4 of 6
bradleyv
NETGEAR Expert
From post: Currently, static routing needs to be setup using the local-only web GUI, but will soon be available in the Insight mobile app and Insight Cloud portal, so stay tuned for that!
Message 5 of 6
bradleyv
NETGEAR Expert
New for IM5.0, is static routing setup within the Insight mobile app and Insight Cloud portal!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 7150 views
  • 3 kudos
  • 3 in conversation
Announcements
