Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi on VLAN GC728X
JohndB
Initiate
Wifi on VLAN GC728X
Hi There,
I have a customer with an GC728X switch.
There are two network configured on a Ubiquty Wifi AP and an Ubiquty gateway.
192.168.1.x for the business LAN and wifi
200.254.254.x for a wifi guest network with VLAN ID 20
The wifi ap is connected to port 13
I've made all the ports a member of VLAN ID 20 and VLAN ID 1. I can connect to the wifi guest network but do not receive an IP Address.
Can some please tell me how to configure this?
Thanks in advance!
Best regards,
John
Model: GC728X| Insight Managed 28-port Smart Cloud Switches
Message 1 of 3
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Wifi on VLAN GC728X
Hi JohndB,
Welcome to our community! 🙂
You may need to assign the ports as T or Tagged going to the router and to your AP so that it can passthrough the VLAN in your switch. Please make sure that every VLAN aware devices was set to Tagged.
e.g.
GC728X
Port 1 - Ubiquity Gateway
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
Port 13 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
Then try to do ipconfig/renew and let's see if it will now provide an IP.
Message 2 of 3
All Replies
JohnC_V
NETGEAR Moderator
Hi JohndB,
e.g.
GC728X
Port 13 - Wifi AP
VLAN 1
Port 1 - T - PVID 1
VLAN 20
Port 1 - T - PVID 1
Message 2 of 3
JohndB
Initiate
Thanks JohnCarloV,
It's solved now and I've learned someting 😉
Best regards,
John
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3144 views
  • 2 kudos
  • 2 in conversation
Announcements
