Reply
Transmission 2.42 on readynas : OK
Hi,
perhaps some of you try to build the last release of transmission on readynas NV+ (sparc).
it is possible ! :roll:
The web interface is more faster.
Firmware readynas : 4.1.8
previous addon : transmission 2.33 from super-poussin
prerequisites :
update libevent to 2.0.15
update intltool to 0.35
add :
/etc/profile
LD_LIBRARY_PATH="/usr/local/lib"
export LD_LIBRARY_PATH
LIBEVENT_LIBS="-L/usr/local/lib -levent"
export LIBEVENT_LIBS
command line to build transmission :
./configure --build=sparc-linux target=sparc-linux --disable-nls
make –s
make install
Re: Transmission 2.42 on readynas : OK
Hello,
Can you make a add-on file for this one? A lot of people going to be very happy for a file for this one Smiley Happy
Regards
sorry,
I didn't know how do that. And I searched many days to build it due to dependance libevent and intltool.
I think the member "super-poussin" is the best man to built a secure add-on.
Can you please be a bit less cryptic?
How to make the updates? Using wget? To which urls?
The additional code should be added at the end of the profile file?
Thanks
=> not understood.
=> make for libevent ( libevent-2.0.15-stable )
=> debian package for intltool (dpkg -i intltool-debian_0.35.0+20060710.1_all.deb, and replace binary extracted from /usr/local/share to /usr/bin)
=> yes
1/
And don't forget before start :
Make a backup of transmission folder (/addons-config), libevent binary (/usr/lib) and intltool (/usr/bin).
2/
Here a copy of my folders needed to build transmission :
http://dl.free.fr/e1DRUWV3C
(all binary are already available due the "make" and "configure" from these folders)
from 4.1.8 firmware, sparc platforms and transmission package 2.33,
intltool = (dpkg -i intltool-debian_0.35.0+20060710.1_all.deb, and replace binary extracted from /usr/local/share to /usr/bin)
libevent = (execute in command line just a "make install" from libevent)
transmission = (execute in command line just a "make install")
Virtuoso
2.42 addon is out
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
super-poussin wrote:
2.42 addon is out
thanks :wink:
2.42 addon is out
is there any plan to release this standalone for x86?
Everytime I've tried to install many of the latest versions of Transmission, I always get the popup error :
"The Transmission add-on encountered an error during installation."
A few seconds later come the three popup menus telling me to adjust my settings.json and it's installed. However, I have had problems getting any of them to actually start (they appear started in the frontview GUI, but via SSH everything seems dead and won't start).
I realise there is little support around this addon, so have been trying for a couple of months on and off to fix it myself. Does anyone know WHERE the error encountered during installation would be logged ? Or anyway of disassembling the "bin" add-on file to look at the scripts (maybe I'm using a share directory name than conflicts with the install, etc.) ?
Many thanks,
Ben
Virtuoso
2.42 addon is out
x86 verwion is out available in frontview , will also publish a link
Where I'm teaching
4B Perros
Tutor
There's two minor issues with the x86 2.42 release;
Firstly it takes over 30 seconds to "start" when enabled in frontview, and once it starts frontview incorrectly displays a message that it failed to start (even though it does start successfully). So there's an issue between the frontview portion of the add-on and the transmission service itself.
Secondly, the service DOES fail to start once the NAS is restarted, and a manual restart has to be performed. This leads to the same behaviour described above, but it does start and can be used.
Currently not experiencing any other stability issues (i.e: crashing or high CPU usage) but this is more likely due to the fact i'm only seeding one item and not downloading anything else.
[EDIT]: Just checked the transtart.sh, transtop.sh and blocklist.sh files as suggested by super-poussin in this thread (although he's referring to the SPARC version);
viewtopic.php?f=36&t=52212
Anyway, the password for the admin user, as specified in these files is still saying "password1" even though I've changed the password for the admin user. So I manually changed the password for those three files to what I set via the web interface. Transmission still takes a bit longer to start up, but now says "Transmission Service Started" instead of "Failed To Start". Not tried a reboot or blocklist check as of yet, as the NAS is busy doing other stuff.
My guess, permissions issue on those three files?
NAS1: Asustor AS-5104T [FW: 2.5.1.RB62] - Drives: 4x WD-Red 68EUZN0 2TB - RAM: 8GB]
NAS2: Netgear Repertoire U4 (Chirpa Special) [FW: 4.2.28 - Drives: 4x WD-Red 68AX9N0 2TB - RAM: 4GB]
Switch (N1): Netgear GS108Tv2 [FW: v5.4.2.19] | Switch (N2): Netgear GS208 over PWRL-1200+
Router: Netgear WNDR4300 [FW: v1.0.2.80] | UPS: APC SMT-1500I, BackUPS ES-700uk]
Where can I find transmission 2.42 for x86 Readynas Ultra 4?
NETGEAR Moderator
You can find a link to the latest Transmission release in here: http://www.readynas.com/contributed/super-poussin/x86/TRANSMISSION_CURRENT.xml
Thanks. Why this is not easily reachable from either the readynas web site or from the frontview web interface?
NETGEAR Moderator
Maybe super-poussin hasn't had time to post the link yet.
With my knowledge of the ReadyNAS SDK (http://www.readynas.com/sdk) and considering super-poussin's earlier posts the update is available for those who already have the latest version linked to on the site installed.
If you download the latest version in the thread and open it in a text editor you will find the available add-on XML link. When the add-on is installed, on RAIDiator 4.2.16 or later if you go to Add-ons > Installed, Frontview will check the XML file to see if it refers to a newer version and if so will provide a button suggesting you upgrade.
2.42 has been running nicely on my Duo for a couple of months now. The previous versions kept crashing. So, first of all, thanks to SP for compiling this version for us!
What always bugged me with the new version was the very slow start of the torrents. Somehow they just didn't get the announce correctly from the tracker and kept idling around. After a while, they mostly began downloading though.
For a couple of days I noticed issues with announces for all kinds of trackers and also at seeding torrents. They only show "Announce is queued" in the Tracker-tab of the inspector.
I searched the Transmission-bug-tracker for this, but it seems that this issue should have been resolved for a couple of versions.
Transmission hogs 98% of my Duos CPU, although nothing seems to happen there. There are a couple of hundred torrents in there, but it never choked before.
I tried restart/reboot. DHT is disabled, LPD enabled.
Does anybody notice this, too, or has a hint on how to resolve it?
Thanks!
Daniel
Discussion Stats
  • 15 replies
  • 1457 views
  • 0 kudos
  • 10 in conversation
