Reply
Transmission setup procedure
Hi all...out there....I have just install the latest Transmission add-on on my ReadyNas Ultra 2 Plus.....is there any procedure to set it up....without having to o through thousands of threads......Thanks to any reply.....
Nas : Ultra 2 Plus
Network : Netgear DGN2200
Desktop : QuadCore I7 950 3.02 GHZ,2 SSD OCZ Vertex4 Raid 0, 1 SSD OCZ Vertex Turbo 60 GB, Gigabyte X58A UD5 Rev2 Bios FD, CORSAIR Vengeance 12 GB DDR3 1600 or OCZ Platinum LV 6GB DDR3 1600 MHz, Thermaltake Armor + Black, Sapphire Radeon 5830 1GB DDR5, Zalmann CNPS9900 Max, Corsair 750 Watts TX
OS : Windows 7 64 Bit Ultimate.
Virtualized with VirtualBox and/or with VMWare : Ubuntu - Fedora 15 - Windows XP -Windows NT 4.0 - Windows 2000 Pro - NextStep 3.3 - Mac OS X Snow Leopard - OpenStep - Windows 7 64 Bit Ultimate - Windows 8.1 Pro - Fedora 15 64 bit - ReadyNAS OS 6 - RAIDiator-4.2.23
Re: Transmission setup procedure
By default,all downloaded torrent files will save to /c/media/BitTorrent,also you may customize the folder where to save your files.
Additional,you can also set download/upload speed thru transmisson Web interface,I think Transmisson is very easier to config,what else you want need to do?
Discussion Stats
  • 1 reply
  • 1060 views
  • 0 kudos
  • 2 in conversation
