Reply
Virtuoso
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
ReadyNAS 528X, Pro 6, ProBusiness, Ultra 4, NV+
Guide
Re: [req] Subsonic
You saw that it is java based? Will make installation fun...
NAS: Ultra-4, NV+ & Duo v2 :: ST31500341AS & HDS723020BLA642 Drives
Network: Netgear GS108Tv2 / DM111P :: Airport Extreme / Express & Time Capsule
Clients: OS X 10.6 - 10.8 :: Ubuntu 11.x :: Win 7 + SP#1
UPS: APC ES-550
Guide
Re: [req] Subsonic
But possible:
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
can you pm me the step by step I will do the addon Smiley Happy
If you like my add-ons - Si vous aimez mes add-ons :
EN/US: --- -------- FR: or Paypal @mail: readynas@orange.fr
Where I'm teaching
4B Perros
Guide
Re: [req] Subsonic
Will Do
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
work and test in progress
need to tweak some scripts Smiley Happy
many thanks sphardy
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
addon ready with ffmpeg and lame Smiley Happy
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
1.1 with JAVA
1.1 without JAVA for people already install java (not ready)
please report bugs
if subsonic says lame is not installed , give me ssh access to check Smiley Happy
Where I'm teaching
4B Perros
Guide
Re: [req] Subsonic
S-P - is java included in this version, or will that be a separate addon?
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
java is included
wait 1.1 for better startup
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
will produce a version without java
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
1.1 with java is out
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
addon is here
viewtopic.php?f=48&t=45661
Where I'm teaching
4B Perros
Virtuoso
Re: [req] Subsonic
damn you guys are fast, and rock! will check it out
Virtuoso
Re: [req] Subsonic
installed 1.1 with java, but it keeps saying no music folders found.
the music path looks right and there is audio there, so not sure whats going on.
edit: never mind, looks like path was wrong case, damn linux case-sensitivity
Virtuoso
Re: [req] Subsonic
Hah it was working great but I'm guessing the search indexer ran out of memory since now I can't access it (and I'm not at home to check).
I'm nearing 200k tracks, so I'll have to figure out how much to allocate. I wish it managed its memory dynamically, but I think its a java problem more than app.
Virtuoso
Re: [req] Subsonic
hmm where is config file stored? I looked for it, its not in the location indicated @ http://www.activeobjects.no/subsonic/fo ... php?t=3939
Guide
Re: [req] Subsonic
/c/webroot/subsonic
Memory size is set at startup so check subsonic.sh (I think)
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
got it thanks!
this thing is so much better than orb, at least for audio, and the android client is slick (and free)
Guide
Re: [req] Subsonic
Anyone noticed Subsonic crashing without notice? And not seeming to be related to memory?
Last couple of times I've gone back to it, it has crashed. No info in the logs at all.
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
yea I've had it crash a few times, I thought it was memory but perhaps its not.
I see alot of errors when downloading art too.
Guide
Re: [req] Subsonic
I've up'ed the memory just in case - let's see but i believe we should see something in the log if it's then known issue
Re cover art - looks like that broke very recently, due to the site subsonic scrapes from making changes. Apparently has affected XBMC too
UPS: APC ES-550
Virtuoso
Re: [req] Subsonic
yea mines down since i got to work, made me mad... I had changed search update to every 3 days, so I don't think that was it.
Also updated max memory to 600 but doesn't seem to have helped.
going to disable the download art thing and see if its more stable.
Virtuoso
Re: [req] Subsonic
it seemed to crash even with download art disabled, so not sure whats up, I haven't had time to sift through the log
while its running, it works great tho.
might not be the only ones having it crash
http://www.activeobjects.no/subsonic/fo ... php?t=4333
Guide
Re: [req] Subsonic
Ummm... It may be memory related.
I up'ed the memory allocation on my setup. My library is not so big - around 5K tracks (25GB) - but SubSonic has not crashed since.
But if this is the issue, then there is still an issue as SubSonic seems to be very memory hungry...
UPS: APC ES-550
Discussion Stats
