- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access management VLAN from other VLANs
- Mark as New
- Bookmark
- Subscribe
- Permalink
We will soon replace our switches with managed switches from Netgear (a couple of GS724T and one GSM7224).
I've been successfully testing a multiple VLAN config with the GSM7224 handling the inter-VLAN routing.
We're planning on separating our network into 4 VLANs:
VLAN 10 = Servers and PCs/laptops (192.168.0.x/24)
VLAN 20 = IP Phones and IP PBX (192.168.2.0/24)
VLAN 30 = IP serveillance cameras (192.168.3.0/24)
VLAN 40 = Wifi (192.168.4.0/24)
Every subnet can reach the others using inter-VLAN routing.
We're leaving the management VLAN number 1 untouched.
My question is how will I be able to manage these switches (ie get access to the web gui) from my PC which will be part of VLAN 10?
I know that for security reason the GSM7224 will not let me route traffic for VLAN 1.
So how do I do this?
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access management VLAN from other VLANs
When you use VLAN routing, choose one switch to be the core switch layer 3 (router) e the others just layer 2. If you don´t aply any ACL to them, you´ll be able to access the management interface in every switch on the ip address that you configured on the switches. We configured 1 VLAN layer 3 to be the management VLAN e use OSPF for distribue the statics routes. In that VLAN, all the switches have one IP address and we access the interface with this IP. This VLAN isn´t the VLAN 1. It works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This way, then you can completely remove VLAN1 and use the other VLAN as management.
- Mark as New
- Bookmark
- Subscribe
- Permalink
